Usb drive shows as two drives when connected
fez
fez
Caporegime
22 Aug 2008
Tunbridge Wells
Hi,
I have a 4gb usb drive that always seems to show as a 4gb drive and a 2mb drive in mac os x. I cant amalgamate them because in disk utility they show up as two drives, separate. I have erased both and it has not made a difference.
Any ideas mac buffs?
Cheers for the replies guys,
There is no option in disk utility for reformatting into a single drive. They are both separate entities according to os x and they have no options that will apply to both.
I dont think its an encrypted drive but that was the only thing that I could think of that would cause this problem. You should still be able to remove this encrypted area though? It should just show up as a single drive with 2 partitions I thought as well.
Very odd, its had a fair bit of use so its a little hard to find out the model but it seems like that is the only way this will be put to bed.
Thanks for all the help chaps.
I have quite a few USB memory sticks, and the only ones which show up as 2 drives are the ones with encryption options.
What brand is the drive?
USB sticks used to be pre-loaded with software but now I've noticed a format doesn't get rid of it so it's obviously stored separately - and it annoys the hell out of me. I'd gladly pay more for a usb stick that doesn't include junk that insists on running when you insert it.
