Are there small USB monitors avaialble ( 5"-7" )
Ive gathered there needs to be rendering hardware built into the panel ( ASIC ) as theres nothing for the USB to render , the reason for this is a project , id rather not use a HDMI or DP driven panel as its a PITA to wire without cables running out of a chassis and into the back of the GPU and look clean.
What other alternatives are there for a panel to sit inside a case and by which means to connect them ?
