USB Flash app
26 Feb 2004
Hampshire, England.
Hi guys,
I had a free Windows app, not so long back, told you the actual size of the memory - manufacturer etc., speed. I used it to check a Chinese stick I bought, everything was Kosher with it so I removed the app. I need it again for work now, our admins have just bought a lot of Chinese sticks and I know they're going to be iffy... can't remember the name though :rolleyes:
Any ideas? It might have had 'check' in the title.
Thanks.
H2testw was developed to test USB sticks for various kinds of errors.
It can also be used for any other storage media like memory cards,
internal and external hard drives and even network volumes.
The executable file H2testw.exe needs no installation and can be
directly run. It was developed for Windows XP and Vista. It should
also work under Windows 2000 but was only tested on XP and Vista.
Windows 9x/ME is not supported. You can use the older command line
program H2test under these operating systems.
The function of H2testw is quite simple: It fills the chosen target
directory with test data and then reads it back and verifies it.
I still have this but my version does definitely not run under windows 10.
