USB Flash Encryption software
18 Oct 2002
West Midlands
I need a utility to install on 50+ USB flash drives that will protect the entire drive and all it's contents.
Does anyone know of such a utility that will do this?
Plug in --> Enter password --> Files are available.
I am really struggling to find something that can do this, it must also not need to be installed on any local hardware.
Thanks in advance for all the help!
Thanks for those, however needing admin rights after the drive is setup is no good as this cannot be done.
I really need this to be installed as a standalone .exe that can be run and has on the fly decryption and encryption. I am really struggling to find something suitable, or is there nothing that exsists like this?
FreeOTFE Explorer does that! :p
Did you not read about the differences between FreeOTFE and FreeOTFE Explorer?
It's a standalone .exe that lives on the USB stick. No admin needed at all.
I use an Integral Crypto USB which sounds like what you need if its just Windows you use it on.
Plug it in to Windows machine, password box pops up and you put in the password, files available.
Not sure if OcUK sell them though - I have a couple of 8Gb and some 2Gb.
