usb front fascia on older pc
6 Sep 2016
I'm probably going to pickup a couple of these
https://www.overclockers.co.uk/akas...3.0-and-usb2.0-hub-ak-icr-12v3-ca-076-ak.html
My pcs are x58a and 870a chipset so older design. They do have usb3 controller bit the ports are round the back on the backplate.
I'm not sure if they gave terminal connectors on the motherboard, but if they don't how would I eire them up, unless I use usb to usb cable round back but that probably isn't ideal.
Except few odd ones all connector panels have USB header cables.
There are cables for turning normal USB ports back to header:
CRJ 9-Pin USB IDC Dupont Male Header to Dual USB 2.0 Type A Male Cable
RAYSUN Dual 2 Port USB 3.0 A Type Male to 20Pin Header Male Slot Adapter
