Hi all, im trying to connect a Xbox 360 for Windows controller to my HP Laptop. Everytime i connect it, i get a balloon at the bottom saying the device cannot be recognised and has malfunctioned. Im using Windows 7 x64, i know this is not a problem with the Xbox 360 controller as i can connect it to another windows 7 x86 pc perfectly.
Ive tried installing the driver software for the controller first, then connecting the device, and the other way round, tried connecting first then installing driver software. nothing seems to work though
Also ive tried uninstalling and removing all usb devices, even changed the power scheme options , for some reason its not picking the controller up and is malfunctioning.
Anybody got any suggestions i can try? All my other USB devices work flawlessly, and as said the Xbox 360 pad works on another windows 7 pc perfectly.
Thanks in advance
Thanks in advance
