Hi,
My motherboard has just one internal 9 pin USB header. This is supposed to support two USB devices (since it's meant to be where you plug your case front USB into). I have two other (fan controller, and PSU) that need USB connections. These appear to be 4 or 5 pin female plugs.
So. Is it as simple as I plug one into the top row, and one into the second row (observing the right +'s and -'s). Or do I need a special adapter (which I have yet to find)
