USB headset problem
25 Jul 2005
Hi all, wonder if you can help me with this. I bought a usb headset a few months ago and it worked fine for a few weeks. Then all of a sudden, the sound became very crackly. I thought it was just the headset at first, so I took it back and got a replacement. I plugged it in and it had the same problem. I have just tried using it in Linux and it works perfectly, so it's obviously some kind of software issue, not sure what else to try though apart from the obvious stuff (making sure it's set to default device etc).
Any help would be appreciated, thanks.
