Usb headset with Soundblaster z
12 Dec 2012
I have a pair of wired HyperX cloud 2 headphones.
1. They came with a usb soundcard fob. Will they work (headphone and mic) without it, by plugging directly into my sound blaster z.
2. If so can I get an extension cable as the audio jack cable that plugs into the usb is very short.
3. Will there be a notable difference in quality using the usb soundcard Vs the Soundblaster Z
you will need a trrs spliter search for CTIA 3.5mm 2 Male to 1 Female Headset Adapter for Gaming Headset at the rain forest
as for sound quality you will have to try them with the soundblaster too find out which suits you best
