USB help needed with Xbox 360
16 Nov 2011
Nottingham
Hey, I purchased a 15gb usb flash drive and when i configure it with my xbox 360 and then put it onto my pc it only has 300kb/15gb left so i cant do nothing with it and when i format it i have to re-configure and the memory is used up again.
Any help appreciated, thankls.
Xbox storage is in a proprietary format. You can't use USB flash drives to backup/copy xbox information to a PC.
You can set the size of the 360 storage on the dash or put in a smaller GB stick, format for storage. Then copy or cut and paste the hidden Xbox360 folder via PC onto a larger stick.
