- 22 Feb 2014
I have a powered 7 port TP link hub, that works fine, using an amazon basics USB to micro USB cable, but the issue is that the slightest movement and the stupid connector pulls out of the back of the hub (it is mounted to my Sim Rig)
so I bought this from ebay
that way I can wrap a zip tie around the hub and physically stop it pulling out the back of the hub.
and then connected it to the PC with a 3m USB 3.0 a>b cable and my wheelbase just wouldn't stay connected longer than a few seconds
so I changed the cable to a 2m'ish one and it works fine.
so then ordered a rhino cables 3m cable and having the same issue as the first 3m cable.
is this issue likely to be the 3m cable or the adapter I bought off ebay ?
I'm thinking at this point of just getting a new USB hub, but I was trying to avoid spending £50 when I have a perfectly working USB hub already.
USB-B 3.0 Female to Micro-B USB Male Panel Mount Cable Right Angle - 0.3m | eBay
USB 3.0 Type B Female to Micro B Male 10pin 90 degree cable With Panel Mount Screw Holes 2. 1 x 30cm USB 3.0 Type B Female to 90 Degree Micro B Male Panel Mount Cable. USB 3.0 A Female to USB 3.0 A Female Panel Mount Extension Coupler Adapter.
www.ebay.co.uk
