- 26 May 2008
Hi all,
Recently my PC has stopped accepting USB connectios such as my camera or USB pen drives.
When I stick my camera, my mates USB stick, or my own USB stick, and the mobile phones into any USB port on my PC I get the following message.
You need to format the disk in drive F before you can use it.
Now this is not correct, as I have had these drives connected before, they have stuff on them I want to access and I do not think formatting is the answer.
If I close the above box and try and access any of these drives I again get the above format message, and when I close that I get the following.
F is not accessible.
The volume does not contain a recognised file system.
Please make sure that all the required file system drivers are loaded and that the volume is not corrupted.
Computer is running Windows 7 Ultimate 64bit, the above drives and camera used to work fine with this PC's USB connections.
Any ideas on what is wrong with this?
I have no issues with any of the above on my media PC which is also running the same OS.
