USB Issues
10 Nov 2011
Telford
Its been happneing for a couple of weeks now where whilst I'm playing games i get the usb disconnected and reconnected sounds.
Not sure whats disconnecting think it may be the mouse for a split second
Currently using
Razer blackwidow
Razer deathadder
Razer orbweaver
Razer firefly
Are all plugged in.
I've unticked the sleep usb devices in device manager under usb hubs.
Also turned it off in power settings.
Is windows configured to install drivers? If so you could try disabling it. Uninstall the drivers for your Razer USB devices, reboot, then install the official drivers.
