USB Keeps Mounting & Ejecting Automatically!
7 Mar 2007
Birmingham, UK
Hi there, i have a problem, i have a little usb reader which reads M2/microSD cards, when my microSD is inserted it works fine, comes up in my computer fine, but when i try any of the 2 M2 cards i have (512mb and 8GB, both sandisks, came with mobile phones, so most probably real) they fail to be picked up in my computer.
But the thing is, i can hear the sounds fine, as in when it detects the usb, and the 'eject' sound, but nothing's happening, it just runs in a cycle, and i cant see or access the usb from my computer, i can see USB Mass Storage Device in Device Manager, and each time it runs its little mounting/ejecting cycle the Device Manager refreshes but the USB Mass Storage Device is still there?!
I don't understand whats happening, and would really like to fix this :(, i could really use the 8GB M2 card atm
Have you looked at the female USB port? Could be physically damaged, try the other ports on the mobo and see!
Nope, still getting the same response, a mounting/ejecting sounds cycle, but nothing actually turning up in My Computer :/
I had a similar problem with a MicroSD card reader. Just kept mounting and ejecting.
It may sound a little silly but 'Have you tried turning the computer off and on again?' It worked for me. Still not sure what went wrong. Although as it has been 3 days since the original post, you probably have.
Yeah ive tried restarting, same outcome :(
