30 Dec 2016 at 11:43 #1 Yaayuh! Yaayuh! Soldato Joined 5 Nov 2010 Posts 24,627 Location Hertfordshire Any recommendations on a USB LED strip, white @ around 4000-4500K and no more than 50cms in length? TIA.
31 Dec 2016 at 12:36 #2 ExRayTed ExRayTed Soldato Joined 18 Oct 2002 Posts 7,782 Location Surrey I've used these before. Bright and none of the fixing issues that you can get with adhesive pads https://www.overclockers.co.uk/bitf...onnect-15-led-strip-30cm-white-cm-238-bx.html
31 Dec 2016 at 14:40 #3 Doogles Doogles Soldato Joined 22 Mar 2014 Posts 3,956 ExRayTed said: I've used these before. Bright and none of the fixing issues that you can get with adhesive pads https://www.overclockers.co.uk/bitf...onnect-15-led-strip-30cm-white-cm-238-bx.html Click to expand... Non branded ones are about £5 though.
31 Dec 2016 at 18:04 #4 ExRayTed ExRayTed Soldato Joined 18 Oct 2002 Posts 7,782 Location Surrey Doogles said: Non branded ones are about £5 though. Click to expand... Not magnetic ones and not available here. Besides, I'd personally prefer branded ones to be honest.
2 Jan 2017 at 09:22 #5 Yaayuh! Yaayuh! Soldato OP Joined 5 Nov 2010 Posts 24,627 Location Hertfordshire Thanks, but I'm looking for a 5V one with USB to power.
