been having problems with my pc shutting down and rebooting, so i have removed the battery to reset the bios and everything seemed ok at first.
I shut down the pc to move it back in place plugged my new Cyborg v7 keyboard in which has worked ok before. When the pc started all the lights on the keyboard were on and wouldnt switch off, so I shut down plugged the keyboard into another usb socket on the front of my case and all was well for a while, I went to adjust the lights and the pc shut down with the fans still going.
So is it the keyboard thats the problem or my usb ports.
I have now plugged in a basic usb keyboard to see if anything happens again
