I'm not sure if what I'm looking for exists on it's own. I have seen sound systems with a USB input so that you can place music onto a USB flash drive,plug it into the sound system and select/play your music, I already own a decent sound system but it only has the usual optical/RCA etc inputs (it's a Sony DA1200ES)
At the moment, I use a bluetooth to 3.5mm unit and stream from my phone,but the signal isn't the best.
I know they do similar units for TVs that don't have a USB input, it can be used to play movies from a USB and output through a HDMI.
I'm looking for a device with a USB input, and a 3.5mm/optical or RCA output with a screen and a few control buttons so I can place MP3s and music on my flash drive and play it through my sound system.
Any help would be appreciated.
Thanks,
Thanks,
