Usb/Mem Card Reader On 2405FPW
16 Jun 2005
Doncaster
How do i get these to work? i've downloaded the driver but when i try to install it vista tells me the driver is up to date but it just shows as generic monitor :confused:
i'm using vista 64bit
what/which usb cable :confused:
I've tried using it to charge my ipod but it doesn't work, but it works fine when connected to my p.c
The card reader wont work by itself, it needs a data cable - USB in this case, it will be in the box with your DVI/VGA leads.
I think i might of chucked it then :o can these cable be bought for a few quid? which type of usb lead is it?
