Hi,
At school, pupils and staff have never been able to use their USB memory sticks correctly on our old Windows Server 2000 network with Windows XP pro clients. We are in the process of upgrading at the moment and now have Windows Server 2003 servers and Windows XP Pro clients and also have Ranger installed as before but with the addition of GateKeeper which was sold to us under the impression that it would solve our problem with pen drives.
Now our problem is that the users have H:\ set as their home drive, default open/save path etc and this in itself is no problem. We also have an Avantis CD Server which puts logical drives on the clients- D:\ E:\ and F:\ with G:\ being the local CD Drive so in theory, the USB stick would use I:\ but instead it tries to use H:\ which is already taken by the home directory. So then, the USB stick either does nothing or takes over H:\ which is then useless as the user has nowhere to save the things on their pen drive
The home directory is set in the user profile in active directory and then Ranger fiddles with things on it so this is near impossible to change the letter which the home drive uses so we need a way to force the pen drive to use avaliable letters after H:\. We've been playing around in:
HKLM\System\MountedDevices
but without much luck. One things I did think of was putting a few lines in the logon script with KiX:
but I'm not sure whether it will work
Sorry for the long post and we would appreciate any help
Thanks,
Ben
The home directory is set in the user profile in active directory and then Ranger fiddles with things on it so this is near impossible to change the letter which the home drive uses so we need a way to force the pen drive to use avaliable letters after H:\. We've been playing around in:HKLM\System\MountedDevices
Code:
USE H: \DELETE
IF InGroup("2001")
USE H: ("\\server\home$\year11\@UserID")
ENDIF
IF InGroup("2002")
USE H: ("\\server\home$\year10\@UserID")
ENDIF
IF InGroup("2003")
USE H: ("\\server\home$\year9\@UserID")
ENDIF
IF InGroup("2004")
USE H: ("\\server\home$\year8\@UserID")
ENDIF
IF InGroup("2005")
USE H: ("\\server\home$\year7\@UserID")
ENDIF
Thanks,
Ben
