USB on tv
Hi there,
Do you mean a headphone output?
There may not be a specific 3.5mm stereo output port on your TV, but it will almost certainly have a set of L/R Phono (RCA) audio out ports. Using a cheap cable (like this, but with 3.5mm end being female type instead of male).
I'm pretty sure the USB port will not with USB headphones - as these ports are generally only usable with USB storage devices.
May I ask what make and model of TV you have?
Sorry, when I google "Bush LTF24M4" it only shows this thread. Is there any other names or model numbers it uses?
Can you see the pair of phono audio-out ports on the back/side of the TV? One will be red, the other is white.
Here is some info on it...
onnectivity:
2 HDMI sockets.
1 SCART socket.
PC input socket.
Component video socket.
Composite.
DC socket (rear).
1 USB port.
Sound quality:
NICAM stereo sound system.
2 x 3 watts RMS power output.
Digital features:
no outputs on there from what I can see. You would have to wire your xbox and wii to your headphones. You wouldn't be able to use headphones for tv
