USB Partitions
25 Dec 2002
Brighton
Does anybody know how I can delete the 2 partitions on my USB drive and just create 1?
Cant seem to find any free partition managers that support usb for free
Is this a USB hard drive or a USB memory stick?
USB hard drives should act exactly like a normal drive, so you should be able to manage your partitions in windows itself, right click on My Computer and choose Manage.
Now select the Disk Management item from the list on the left of the Computer Management window and you should be able to figure the rest out from there. :)
If it is a USB memory stick then is a U3 enabled device?, if so you can download a program from the U3 apps website that will remove the second partition.
U3 allows you to install portable applications onto the memory stick so you have your favourite programs everywhere you go.
It appears the Super Talent memory sticks do not have U3 technology so it should be pretty straight forward to sort out.
Yes it does it shows up as 2 removable hard drives O:\ & N:\
Ive treid the lexar USB utility but that didnt work
