25 Feb 2017 at 11:19 #1 sharper9 sharper9 Associate Joined 11 Nov 2009 Posts 14 Looking for a plug for iPad/iPhone and Nest 3rd Gen. These are the type of thing I'm looking for but they are only an example. Need to make sure they can charge at the correct rate. For Nest etc Any pointers gratefully appreciated.
25 Feb 2017 at 11:38 #2 Nazbit Nazbit Soldato Joined 11 Dec 2004 Posts 3,871 Dont know the current draw of nest but a plug with 2 x 2amp usb sockets will be fine. Edit - rainforest - B016LPMFUA
25 Feb 2017 at 12:29 #3 Django x2 Django x2 Soldato Joined 28 Sep 2008 Posts 14,291 Location Britain Or wire the nest in properly if you can? It's a 10 min job
25 Feb 2017 at 12:49 #4 azibux1 azibux1 Soldato Joined 11 Oct 2011 Posts 3,335 Location UK Django x2 said: Or wire the nest in properly if you can? It's a 10 min job Click to expand... Only if the cabling is easily run or already present though. Depends on the OPs setup?
