Usb port on Sky + box
4 Jul 2005
Just had sky + installed anyone know what the usb port on the front of the box under the flap next to the card slot is for?
There is no memtion of it in the manual.
Not looked at the back yet. The installer only pulled the minimum amount of cable through the wall to the box so it is hard to move it. Will have to sort that out at a later date.
kjbits said:
Was hoping to possibly connect to a pc to see the harddrive.
No chance of that. Sky+ boxes store the encrypted feed, so you can only view the content through the box itself. Otherwise what would stop you just pulling stuff off the box?
