USB ports dead
18 Jan 2007
Land of the Scots
Hey peoples, my old laptop, an Advent is having a bad time, the USB ports seem to have died on it. It was working fine, sold it to my friend and it's just gone downhill from there. When something is plugged in Windows recognises something is there but comes up with "this device was not recognised" and nothing else happens.
Have tried different drivers, re-installing windows (destructive recovery) plugging in a powered hub, but it just seems like the hardware is conking out, can't be any older than 2 years now though.
Anyone got any tips I may not have thought of to try and get it back on it's legs?
if it's out of warranty, if your careful you can take it apart without damaging anything and check if there's anything obvious, occasionaly a large buildup of dust can cause problems, it's unlikely but a clean could help!
Yes it is out of warranty, might have a look inside, it has seen a lot of use so dust could be a problem I guess, depends if he's ok with taking it apart. Just obviously not much else to do, it's either expensive repair or lose out on selling it because the ports don't work. :(
Thanks for the input :)
have you checked the bios to see if usb is on or off?
just an idea any how, but maybe give it a look, tho most laptop bios's are
so basic.
maybe a bios reset might fix it as well
so basic.
If windows is finding the device but not recognising it then they are turned on. Its common for the ports to get knocked and short out the controller this is the symptoms its showing.
If no expansion then its mainboard unfortunately.
