- 9 Dec 2008
Hi,
Ok I know that any one USB port is supposed to have a maximum power supply capacity of 500 mA. And if I understand correctly many or all motherboards have two physically separate USB hubs on the mobo. So first of all, is that right?
The reason I ask is that I need to connect a 2.5" HD via USB to a lappy. The power requirement of the 2.5" HD is exactly 500 mA. The IDE->USB adapter has a USB Y-cable in cases where the power requirement may exceed 500 mA. The Y-cable allows the HD to be connected to two USB ports for 500+500 mA power.
SO, for getting capacity in excess of 500 mA, do I need to make sure to connect the USB Y-cable to the USB ports from two different hubs? Would connecting the cable to two ports on the same hub only give 500 mA instead of 500+500 mA? (again by "hubs" I'm referring to the hubs within the mobo like stated above)
OR, do I totally NOT need to use the Y-cable if the power requirement for the 2.5" HD is specified as 500 mA (the max output of a USB port)?
I need to recover data from the HD in question... which might not end up being possible, because the drive might be corrupted... but need to check.
Thanks
Thanks
