A longer time lurker here now forced out from the woods
Although I’ve had other stuff from OCUK I purchased my first PC from them a Titan Triceratop Intel Core i5 in September of 2011 (Now 3 months back)
IMO the PC is pretty good other than the occasional odd ball and intermittent problem, well actually there are two of them one which is intermittent, the other now seems persistent, however both are related to USB connections.
Oh BTW I should mention the USB connections which give me grief are always the ones which connect a logitech wireless keyboard, but more often than not an hard wired bog standard MS mouse.
1
The PC will go through boot to the opening Windows screen, on rather more occasions than I’d like, the mouse totally fails to respond, however if I pull out and reinsert the USB it then works fine, it’s a bit of a PITA though. The keyboard very occasionally does the same thing but far less often though.
2
But the following problem relating to the keyboard drives me to utter distraction, in the event that I wish to complete a full reinstall although the keyboard will work during POST and allows me to make any desired changes to the Boot sequence in BIOS, once Windows set-up is underway the keyboard stubbornly & totally fails to respond, thus thwarting any attempt to reinstall the OS.
Amazingly if I then allow my XP OS to BOOT with the odd exception described in 1 & 2 above all works fine, the same applies if I go to BIOS.
NB relating to # 2 I’ve tried with three different wireless keyboards / batteries / wireless pickups with exactly the same results.
Any advice would be very much appreciated
Thanks, & an Happy New Year to everyone
Cheers hondo
1
2
Cheers hondo
