usb problem??
25 Jun 2015
Leicester
having a few issues recently which i'm assuming is some kind of usb problem although maybe not
1. Every computer restart my thrustmaster tx wheel registers in gaming controller panel as "thrustmaster ffb wheel' instead of "thrustmaster tx Racing wheel" when it does this i get a generic controller properties panel instead of the thrustmaster properties and the wheel doesn't register in games correctly, disconnecting and reconnecting the wheel solves this completely until restart. For what its worth this is plugged into the first usb 2.0 port on the motherboard.
(most upto date drivers and firmware installed)
2. Sometimes my Thrustmaster TH8A shifter (separate usb) will disappear from my game controllers panel and not function, or be recognised and still not function, again disconnecting and reconnecting the shifter cures this.
(usb 2.0 on motherboard)
3.I have a corsair strafe rgb plugged into front usb 3.0 ports, sometimes the computer will fail to restart with this plugged in, and then fail to boot using the reset or power buttons, if i unplug the keyboard it will boot perfectly.
4.My wheel, shifter and fanatec clubsport handbrake keep changing joyid numbers meaning on games like my summer car i have to reset my controllers pretty much every time i play as for instance sometimes my wheel will be joy1 then joy2 the next time i play it.
any ideas?? its driving me crazy having to reconnect usb cables so often
