USB Problems
23 Oct 2002
N Ireland
Every time I plug a USB device, ie pen drive or external hard drive, into a new Asrock P4VM800 motherboard the PC stops sending a signal to the monitor.This is the second board it is happening with. I have the latest drivers installed on Win XP SP2 with the latest updates. I have flashed the BIOS of the board to the latest one and also tried different RAM and CPU. I have carried out HDD diagnostics and evey thing is reported OK.
The problem sometimes happens as soon as I plug in the device other times it is after a couple of minutes.
I phoned the tech support of the dealer and they have had no reported problems.
Any help would be appreciated
Thanks
Brian
