Caporegime
- 13 May 2003
- Warwickshire
Hi all
My in-laws have BT ADSL and I went round there to install (or try to) a new 'Home Hub' that they've been sent. This is basically an ADSL modem / router.
The problem I have is that there's always a yellow '!' in the device manager, and I cannot get the system to recognised the device. I have been through the entire setup CD and it's told me that the USB drivers have been installed successfully. The error in the device manager is 'This Device Cannot Start. (Code 10)'.
Previously, their internet worked ok via a 'SpeedTouch' 330 modem, but they were having problems with disconnections at peak times, hence me trying them on the home hub. After trying and failing to install the Home Hub, I then tried to get them back to where they were before I started. However, whenever I tried to install the drivers for the SpeedTouch modem, the PC restarted itself!!?
Can anybody guess as to what is going on here? Why can I not get the PC to recognise the Home Hub and why does the PC now restart itself every time I try and install the modem's drivers?
Other info:
- OS: Windows XP with all updates
- Connections: phone port--> filter--> home hub--> PC (via USB cable)
- They have a very old Hewlett Packard PC, for which I've since upgraded the HDD and memory
Many thanks for helping me achieve in-law brownie points!
Other info:
