- 12 Feb 2022
- Norfolk
Hi all!
I've recently purchased my first PC build, after a week of setting it all up, I've got everything up and working, except two things:
The CPU fan works fine, but the rear fan hasn't switched on at all. Not only that, but the RGB lighting on the case and fan don't work at all. There is a 4-pin cable from the fan (there is also a vdg? cable thing next to it) I'm presuming powers the rear fan + lighting, but can't figure out where that would go. The only other loose cables are an 8pin male cable from my PSU(6 +2) and a 15 pin(?) SATA cable that doesn't fit anywhere.
The second issue is that my motherboard's RGB lighting WAS working until I had to move the PC to a different room. Now, although it functions, the lighting is nonexistent. I've tried switching the PC off and on, tried switching the RGB switch off on the motherboard itself but no dice.
I would leave it but it's a bit frustrating considering I paid a fair amount for it, and I'm worried the CPU will overheat when I need to do high-quality coursework on Adobe After Effects.
My build:
Apologies if the answer is obvious, I'm extremely new to all of this!
My build:
- MSI MAG B550 Tomahawk
- AMD Ryzen 5 5600X Six-Core 4.6GHz (Socket AM4) Processor
- Sapphire Radeon RX 6600 Pulse Gaming 8GB GDDR6 PCI-Express Graphics Card
- WD Blue SN550 1TB SSD NVME M.2 2280 PCIe Gen3 Solid State Drive (WDS100T2B0C)
- Corsair Vengeance LPX Black 16GB (2x8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Dual Kit
- Kolink Inspire Series K7 ARGB Midi Tower Case (with the preinstalled rear fan)
