USB Speaker Annoyance
21 Apr 2004
Southampton
I have a minor issue with a set of standalone USB speakers I use sometimes with my PC. Normally if listening to music or playing a game or whatever I use my headset which is connected using a 3.5mm jack on my motherboard. I also have these speakers connected via USB.
For some reason, Windows has stopped detectin the speakers 'by default'. It's always been the case that I can right click on the volume icon in the task bar, select 'audio properties' and toggle between speakers and headset under default audio device. Now though, the speakers don't appear on the list and only come back if I unplug and reconnect them.
This makes me think it's a windows issue. It doesn't seem to be 'noticing' that they're there when I boot up!
Any suggestions? Thanks :)
