USB to Go environment?
26 Feb 2021
Antrim
I have a PC which I would like to install an OS on, typically a router OS just to try them out. The PC has a small MSata drive.
I'm thinking I could use a USB stick to create a live OS environment where I could install/copy accross an iso file.
I'm not too familiar with Linux but I think that is the way to go - any helpful suggestions?
Sounds like Ventoy could be what you are after. Very simple, you copy ISOs to a folder after creating the USB, then you can select any of them to boot from.
That lkooks good - but then what OS to run on the stick that would allow me to create a bootable image on the internal mSata drive, something comparable to Rufus?
