USB to LAN connection to use PC in another room.
23 Mar 2005
I've been tearing my hair out trying to set myself up so I can play games on the PC in the garage from the comfort of my sofa in the lounge. Hopefully someone can spot what I'm missing, as I'm sure this shouldn't be so hard!!
Setup:
Gaming PC in garage
2x Cat 6e cables run between the Garage and Lounge (around 15m each, dual wall socket at both ends.)
PC connects to the internet and LAN via Cat 6 cable to the wall socket in the garage, through the external Cat 6 cable, then Cat 6 cable into a wireless access point in the lounge.
I'm using a Quest 3 which connects flawlessly to the PC and run everything without issue. I've had a long session of HL: Alyx and it was a thing of beauty to be completely wireless.
The problem is, I'm trying to control the PC in the garage with a keyboard and mouse in the lounge. I have tried:
  • Plugging the KB/Mouse dongle directly into the Quest (Logitech KB/M) - works a treat on the quest, but not on the remote PC (apparently an issue with Android that won't passthrough the signal) - to be clear, I can use the KB/Mouse on Native Quest Apps on the headset, but they do not work when trying to use the PC remotely (Remote Desktop and Virtual Desktop tried).
  • Unpowered USB-Ethernet adapters: Used one each end - nothing. When I ran them in the garage, with a bit of cable between them, they worked fine, but will not pass through the external cable. (assumed it was too long for unpowered) so...
  • Powered (alleged good for 60m) usb-ethernet transmitter/receiver. Again, works fine in the garage with about 10m of ethernet between the bits, but will not pass signal through the external cables.
Obviously, I assumed there was an issue with the external cables (the cat may have assisted with the installation of one of them :eek:) but both of them pass internet signal flawlessly so I assume they are fine. I do have a cable tester, but using it when the 2 ends are 10m apart, and separated by a building is challenging!
Any ideas??
All I want to do is play games from my PC, on a big virtual screen in the Quest, controlled by my KB/Mouse while sitting on the sofa.
Who terminated the cables? If the PC works fine and the USB adaptor doesn't (but works on the different, loose cable), maybe PC/router is auto negotiating the cable standard T-568A or T-568B but the USB gizmo can't?
I made all the cables - gone with 'b' across the board. It is possible I messed up both cables, but I'm not convinced - will see if I can bodge an extension to test them both.
I did wonder about cabling, so replaced the old Cat 5 cables that went from the wall sockets to the transmitter and receiver with hand made cat 6 - no difference.
Worked out I was being a biff! As the 2 cables run parallel to each other, and each end has a dual socket box, all I had to do to test both runs was connect one end together, and test the other side... and one of the cables is not right. I thought that would solve my problem, but it turns out the USB-ethernet was on the cable that was correct. Oh well, back to the drawing board.
On the plus side, it shows how robust the management in the access points is - just sorted out my mess and didn't even tell me :)
Fffffffffffff... well, the good news is it now all works. But I honestly have no idea why. Out of desparation I connected everything up, then added the spair 15m cable I had lying around so I could at least bring everything into the same room to troubleshoot. As soon as it knew I was watching - it just started working. Disconnected, set it back up sensibly, and now I am sat on the sofa, happily typing this on a huge virtual screen, cast from the garage PC.
Feel like being back in the late 90s when netwroking was more about superstition than science :rolleyes: - but I shall take the win and move on :D
