- 5 Jul 2007
Hi guys
Having trouble deleting files from & ejecting usb sticks. When I try to delete a file I get the message "the action can't be completed because the file is open in windows explorer, close the file & try again" !?. Not had this before & the stick works fine on another PC !.
If I try to eject the stick I get the message "the device is currently in use, close any programs or windows that might be using the device & try again"...of course I've already closed the window !.
I recently upgraded to USB3 with an ad-on card (VIA controller). Device manager is happy & drivers are up to date. Plugging the stick into an old usb2 socket gives exactly the same problems !?.
Thanks in advance...
