USB TV Tuner Questions
24 Aug 2004
UK
Hi Guys!
Purchased a USB DVB-T Tuner from ebay, just a cheap no brand one, and have a few questions.
Signal with the supplied mini aerial is pants, hooked it up to my main house aerial and got a few more channels but its not amazing, what are your experiences here? is there an aerial or booster that you would reccomend?
came with Blaze HDTV software, seems ok but again not amazing, what do you guys think of this? are there suitable alternatives i should look at?
This tuner picks up freeview channels, and ive seen on a freeview box that they have the listings that appear on the bottom of the scrren like you get with sky/cable (do you know what i mean!?) can I get my tuner to do this?
Thanks in advance everyone
Im still looking for info on this, I have since found out that it is an "EasyTV" USB Tuner, if that helps? Ive not had much luck on google to be honest. Looking around though, it does seem that freeview signal is not that great and most people reccomend a roof mounted aerial, which makes this much less portable than I first thought!
