USB Wi-Fi Adapter won't connect to Router at Start-up?
18 Oct 2002
Peterborough
As per thread title my Netgear USB Wi-Fi Adapter won't connect to my Netgear Router at Windows Start-up automatically?
I have to manually apply the existing settings before it will connect, therefore things like MSN, Google Chat etc are not all automatically connected as they are executed before I have to manually connect the USB Adapter to the Router. Does anyone know why this is, as the settings never change, they are both the latest Netgear compatible products?
use the latest driver, but use the windows software and not the netgear software. depending on the driver, it should connect before login
Ah ok, nice one, just seems weird that it won't work correctly using the netgear utility which seems quite good for all intense purposes.
