Any USB adaptor will do. it all depends on how far away your device is from the router and where it is located in that room. Also what sort of speeds you are expecting from it.
Here is the section on our website. As you can see from here you can get tiny little dongles which are small and compact but not the best at getting a strong signal. Or you can get the ones with an extension cable so you can put the adaptor somewhere where it will get a strong signal.
I hope this helps. If you need any more help please ask.
