USB WiFi dongle recommendation
26 Aug 2010
Hey
So I've just changed my pc around and got a virtual mounted GPU. Wouldn't fit normally in my case by a few mm, was really annoyed when I tried to put the side on :( so a WiFi card won't fit in my pc now
Anyway, what usb donges do you guys recommend. I've just got a cheap one off the bay but it will only do 200mbps were as my old card could get 300-320 so I'm a bit miffed and need more speed from my 350 virgin.
Or would home plus be a better option if my pc is upstairs?
Thanks for any help :)
