Hi all
Here again with another problem.
My P8Z68-V mobo's USB3 header stopped working today. However, the back USB3 ports work fine. I tried connecting another USB front cable from my other computer and it did not work so It's definitely the header is the problem. I have not installed anything or updated anything. I have tried install/uninstalling all usb drivers, reset my bios just in case. Nothing seems to have solved the problem.
Any idea what else I can try to fix this?
Cheers
Cheers
