USBC port protection?
18 May 2010
Hello
Does anyone know of something that permanently plugs into the USBC port and still allows for fast charging and protects the port from fluff etc?
I know that sounds weird but I could have sworn I read on here recently someone used like a magnet adaptor or something and they just leave it in the phones port!
Thanks
Something like this?
Looks like it yeah thanks, is there a go-to brand do you know? Just had a look on Amazon but there are loads and I bet 90% are cheap knock offs
I do this, and it works great for the reasons you've given. Doesn't wear the port out, keeps the carp out, and makes for very easy connection when using android auto in the car. And the type I use does support fast charging etc.
NIMASO Magnetic Charging Cable【2M+2M】USB C to USB C Cable 60W 3A Magnetic Charger Cable PD Charging Lead for Samsung Galaxy S20 Ultra/Note 20 Ultra 5G/S21 Ultra,iPad Pro 2020,MacBook,Google Pixel4 https://amzn.eu/d/0NHvdn4
Great thanks, not got round to buying anything yet so I'll have a look at this
