fumbles said:That first one is the official one and IMO is the best. If you are using XP you can use the old messenger: C:\Program Files\Messenger\msmsgs.exe, it comes with XP and is inbuilt.
Jimmy1983 said:yer the laptop does have this, but when I try to open it, it doesnt open![]()
fumbles said:Tried opening the task manager to check if its running? Sometime it doesn't pop open or display in the system bar thingy (the thing next to the clock). If it's too much hassle don't bother with it IMO. So yeah webmessenger is fairly good.
