Use pc speakers on ps4
22 Nov 2007
Hi
I have recently moved my ps4 next to my pc and am using a spare monitor i had, i don’t really want to buy another pair of speakers as i only play fifa on the ps4.
So is there anyway i can use the pc speakers on the ps4 without having to hook up the cables each time?
What connection is it from the speakers to the PC? Optical, aux cable, usb? You can get a switch box and then just get an optical converter to 3.5m jack, that is what I used to do and just switch between the two.
