Usenet speeds
7 Aug 2009
London
Hi guys,
I just recently jumped on the usenet bandwagon and was wondering if there was a way to speed up the download on a single thread?
If it is using 10 thread it flies at like 36mb, but when there is a large single file it will be about 3mb, is this normal?
My provider is newsdemon, thanks for any help :)
Doesn't matter if it's a large file or not, a newreader grabs in chunks. So if you have 10 connections it'll use 10 connections.
What newsreader are you using?
Just checked my Supernews, with 1 connection I can pull 2.5MB/s.
So probably your provider
