Users of vi ..
9 Dec 2004
Dorset
I've got a mahooosive text file of some netware contexts and for each line I need to replace the root container. So for example;
bob.jimmy.centre
needs to be
bob.jimmy.newplace
(on around 2000 lines)
Its probably quite obvious but how can I do this in vi using a global replace command?
:%s/*.*.centre/*.*.newplace/g
Although thats absolute or whatever, so *.*.newplace does actually get pumped in.
Anyone got any ideas?
Thanks for your help.
U lost me abit
My linux pc in bits so i cant test your code
But could you not just cat your text file and pipe it to sed
Code:
cat old.txt | sed -e 's/centre/newplace/g'  > new.txt
depends on your what the rest of your data is like.
...but if they all contain jimmy then try...
:%s/jimmy.centre/jimmy.newplace/g
OR if you are certain that .centre only exists where you want to replace it then just do...
:%s/.centre/.newplace/g
Cheers.
