Using 2gig but ok to put another 4gig in?
2 Dec 2004
Under The Desk, Wales
I have 2gig running at the mo, DDR3 and just bought 4 gig. Is it ok to run the 6gig (3x2g) in my PC? I have an AMD setup, Athlon 635 CPU.
Arnt AMD processors dual channel, you'll want to have either 2 or 4 sticks of ram.
The 3x2Gb kits are sold for Intel i7 LGA1336 computers.
I already have 2gig in my PC but just bought a 4gig set. Was wondering if i should leave the 2gig in and put the 4gig in with it or, take the 2gig out and just put the 4gig in?
dual channel doesn't mean u cant use different memory, it just means if they arn't matched, u dont get dual channel operation for a small performance boost.
whether 4gb dual channel, or 6gb single channel is better would depend on your memory usage.
if you rarely/never use more than 4gb, then running 4gb in dual channel would be the best option.
however, if you tend to go over 4gb of usage, then 6gb would give u the better boost
