Using 3 sticks out of 4
4 Apr 2006
Norwich
as a sub question then, if i had already ordered the 2 sets prior to thinking of actually asking advise.
would i be better with
4 sticks of the new stuff
4 sticks new + 2 old
or 3 + 3
four sticks of the new stuff,youd be running in dual channel mode but with 8gb,you wouldnt notice any difference from 3 sticks of the old stuff running in triple channel
i wouldnt mix the ram it might need a huge amount of dram voltage to get it stable or just might crash a lot,
with 4 sticks of the new stuff i would be up at 16gb would that tip it back in the favour of the new sticks?
ahh thats right,i keep forgetting there 4gb sticks and you have 2gb sticks atm,
just use one kit of the new ram so two sticks of 4gb each=8gb in dual channel vs what you have atm which is 3 sticks of 2gb=6gb in triple channel mode
8gb vs 6gb will be better so you wouldnt see any performance drop from triple channel mode
If that board is triple channel memory then surely you need multiples of 3 RAM sticks. i.e. 3 or 6?
