Using 3rd PCIe slot.
12 Sep 2005
Grundisburgh
I use an Asrock Z68 Extreme 7 Gen 3 motherboard with two GTX680's in PCIe 1 and 4 as recommended in the manual.
GTX680 no 1 is getting quite a bit hotter than card 2, what will be the effect be if I moved card 2 to a PCIe Slot further away from the 1st card - will it in fact even run SLI. Am I looking at new motherboard? !!
Cheers.
Andi.
I understand the GPUs would still run at x16/x8 but there should be no issue with moving to the next PCIe slot. I don't think it will affect performance but it will cool the cards down.
OK that's good, just wondering why the manual says use two slots that are close together. I'll dig out a longer bridge cable and see what happens.
Andi.
Well running 3 GPUs would be x16/x8/x8 so running 2 would be either x16x/x16 or x16/x8 either of which will make no noticeable difference.
I think I'm slightly worried that the motherboard will not support SLI in any other slots than the ones mentioned in the user manual.
Andi.
No SLI with cards in 1 and 5 (both cards recognised by Windows but no option in Geforce control panel to enable SLI) I don't have a long enough bridge for 1-6.
Andi.
ok - I'd recommend using 1 & 3 or 1 & 4 - The cards are getting hot but there is nothing you can do about. What case do you have? Have you looked to change your cooling configuration?
Looks like I've had it. It appears you have to use slot 1 or no SLI is recognised.
2 is covered by the card in slot 1, 3 is an X1 slot (short) 4 is the recommended for 2 way SLI and works, 5 doesn't work and 6 I don't have a long enough bridge cable.
The case is a Thermaltake GT10, it's possible I could fit a small extraction fan between the two video cards.
But I think a new motherboard is going to happen ;-)
Cheers.
Andi.
