Using a archer c7
21 Jun 2018
Im thinking about getting a archer c7 from tp-link, since im new to the networking area i want to ask some questions.
1. Can i use this with a Superhub 3 from Virgin?
2. Can i somehow use it without using modem mode?
3. Is it relatively easy to setup?
What i want to use it for: Gaming using a ethernet cable connected to a switch, and using it for wifi.
Thanks
1. Yes.
2. Why would you want to? If you really feel the need you could configure it as an access point instead of a router.
3. Trivially easy (assuming you know basically what you're doing).
Thanks for the answer, i want to use it since we use ethernet downstairs and i want to have somewhere where i can access both ethernet and wifi using another router i am aware you can use a switch but that doesn't have wifi, also am i correct that QoS will not work whilst using it as an access point and using ethernet will work whilst using it in access point mode?
