i'm trying to connect a sky extender to a friends vista ultimate based PC and cannot find a signal search option, only manually add... it is wired exactly the same as with XP MCE and which was working on that, but the setting was lost with the vista install.
By selecting services on the digital remote, then using 401(select) i've found out that the output RF channel is 68, but am not sure what this is in MHz, any help would be appreciated, as would any on using a beanbag/blaster system (the one from OcUK) within vista
Thanks - Dan
Thanks - Dan
