Hi All,
I need some newbie advice regarding Display Port.
I have recently got a Palit GTX 970 that has mini display port connectors.
I currently have a 3 monitor set up, used for work and some gaming.
I have also just got a new monitor that has a display port connection.
Currently on all 3 monitors i have DVI cables, and 2 of them have active display port adapters.
I cant actually find a display port cable that is normal size one end ( to go in the monitor) and mini display port the other end, ( to go in the graphics card )
I guess the question i'm asking is, is the setup i currently have ok, or should i be using an actual display port cable, one that is normal size one end and small size the other end, and what is the benefit of it?
many thanks
many thanks
